Techmichelle's avatar
Techmichelle
AC1200 / R6120 2.4 wireless NOT working
Hi  Looking for some ideas. Unboxed this router and reset the 2.4 and 5 SSID and password.  I was unable to connect the 2.4.  I did a factory reset.  The 5 connects, the 2.4 does NOT.
Suggestions?
TIA
  • plemans's avatar
    What error do you get?
    do all devices have issues or just one?
    any special characters in the ssid/password? (try removing them if you do)
    • Techmichelle's avatar
      Techmichelle
      Thanks for the idea.  Yes the smart phone can connect to the 2.4.
      Windows 10 Laptop gives a Can't Connect error.
