pinakotal
May 12, 2022Follower
Ac1200-100nas
Hello,I have AC 1200-100nas router and my Spectrum speed is 57 and 9 after reading comments I’ve noticed this is only good for 100mbps and my spectrum is 200mbps so with that being said,I’m looking...
May 12, 2022Guru - Experienced User
so you're wanting a router recommendation?
You put home size, which is excellent. A decent router should cover 1500sq ft.
What is your home made from?
What is your budget? Sadly, we do need to ask that as its bit pointless if we recommend a super expensive one and thats not in your budget.
What do you use it for? Gaming? Just streaming?
I'm a fan of renewed devices as they can be picked up pretty cheap off amazon. Usually the price of a renewed device and a 3rd party warranty (if you're worried about renewed) is still significantly cheaper than anything else.
