AnniePannie
Feb 16, 2021Aspirant
AC1200 Dual Band WiFi range Extender
The extender network does not accept the router password
You have the EX6110?
What firmware is on it?
What router are connecting it to?
Are you setting it up using wps or using the installation wizard?
You posted in the router section and not the extender section. do you have a netgear router as well?
- AnniePannieAspirantyes it's EX6110No idea what firmware (don't know what that is)!Router: provided by Utility Warehouse - on the back it says technicolor DWA0120Tried both for set upDo not have a Netgear router.I tried moving the extender back closer to the router and it connected for a mili second and then disconnected........?
Try factory resetting the EX6110 and reinstalling it 1 more using the installation assistant.
Push and hold reset for 7-15 seconds while the extender is powered on.
then use the installation assistant.
How to Setup your WiFi Range Extender with NETGEAR Installation Assistant - YouTube
