KuanYinTi's avatar
KuanYinTi
Follower
Jul 14, 2017
AC1200 R6120 ROUTER
I just bought Netgear AC1200 R6120 Router and have a question. Can I have 2 different SSID names and 2 separate security passphrases or do I have to use only 1 in both the 2.4 Ghz and the 5 Ghz in the wireless section in Basic once you login to the routerlogin on line? Also can I change the password back to the defualt without any problems? I'm not sure what to do? Help!
  • Hi KuanYinTi,
    Yes, you can set different SSID's and WiFi passwords for the 2.4GHz and 5GHz bands. Yes, you can also change it back to the defaults if you prefer.
    Dexter
    Community Team
1 Reply
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi KuanYinTi,
    Dexter
    Community Team
