Drillerspawn1
Oct 05, 2017Follower
AC1200 R6220 ROUTER keeps disconnecting
I just plugged my router up about 2 weeks ago and from day one, it has been dropping the signal a few times per hour. It drops on 2.4 and 5g. I usually have 1 laptop and 2 cell phones connected to it,...
- Oct 11, 2017
Hi Drillerspawn1,
1. What is the firmware version of the router?
2. If the wired connection through the router also drops, there is a possibility that the connection from your ISP may have an issue.
3. Please try connecting a computer straight to your ISP''s modem and check if the connection is stable.
4. If it is still dropping via the modem, then we recommend contacting your ISP to have it checked.
Dexter
Community Team
DexterJB
Oct 11, 2017NETGEAR Moderator
Hi Drillerspawn1,
Dexter
Community Team
