R6220
4 TopicsR6220 - using a power bank for router power
Hello there... i want to use a power bank(10000mah, 2.01amp) for powering my R6220. i tested it.. and it runs smooth but my question is... is there any problem if i use in that way... cause router needs 12v/1.5a and um giving him 2.01amp( 5v power bank actually,idk it converts 5v to 12v or not). what can i do, if its not good for my router.. ? do i need a 5v to 12v booster usb to dc power cable? or anything else...? Thank youSolvedAC1200 R6220 ROUTER keeps disconnecting
I just plugged my router up about 2 weeks ago and from day one, it has been dropping the signal a few times per hour. It drops on 2.4 and 5g. I usually have 1 laptop and 2 cell phones connected to it, and signal is lost to all of them. I also have one thing plugged into it directly and that loses signal as well. It always comes back on within a few minutes or if I turn the router off and back on. Is there a way to fix this issue or do I need to send it back to Netgear?SolvedR6220 readyshare not working with new genie for iOS
I was using readyshare on my R6220 all afternoon with no issues under the old iOS app. I upgraded to firmware version V1.1.0.34 on my router earlier in the afternoon and still things worked fine. I later upgraded my genie app for iOS to verson 3.1.10, and readyshare is gone. I have validated that the share is still available from my computer and working fine. Is this a bug in 3.1.10? Anyone else seeing this?Solved2.6KViews0likes3Comments
