R6220
5 TopicsR6220 - using a power bank for router power
Hello there... i want to use a power bank(10000mah, 2.01amp) for powering my R6220. i tested it.. and it runs smooth but my question is... is there any problem if i use in that way... cause router needs 12v/1.5a and um giving him 2.01amp( 5v power bank actually,idk it converts 5v to 12v or not). what can i do, if its not good for my router.. ? do i need a 5v to 12v booster usb to dc power cable? or anything else...? Thank youSolvedAC1200 R6220 ROUTER keeps disconnecting
I just plugged my router up about 2 weeks ago and from day one, it has been dropping the signal a few times per hour. It drops on 2.4 and 5g. I usually have 1 laptop and 2 cell phones connected to it, and signal is lost to all of them. I also have one thing plugged into it directly and that loses signal as well. It always comes back on within a few minutes or if I turn the router off and back on. Is there a way to fix this issue or do I need to send it back to Netgear?SolvedR6220 readyshare not working with new genie for iOS
I was using readyshare on my R6220 all afternoon with no issues under the old iOS app. I upgraded to firmware version V1.1.0.34 on my router earlier in the afternoon and still things worked fine. I later upgraded my genie app for iOS to verson 3.1.10, and readyshare is gone. I have validated that the share is still available from my computer and working fine. Is this a bug in 3.1.10? Anyone else seeing this?Solved2.5KViews0likes3CommentsCan't get good signal at my room
Hello, i am having a bit of a trouble to get good signal at my room, the router is placed at the living room and is in front of the hallway, the room that is at the end (2) of the hallway gets excellent signal with very good speed (almost max), but my room (1) which is a little before the room at the end of the hallway doesn't get good signal, sometimes signal dropping on my iphone when i'm in bed.12KViews0likes0Comments
