Luz05's avatar
Luz05
AC1200 wifi router R6120 problemas de conexion wifi
  • plemans's avatar
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
      • plemans's avatar
        not much to go on. Just a router model.
        To get a hold of support. Click on "MyNetgear" at the top.
        Register an account (or login) and then the device.
        From there you can start the support process. Keep in mind that its only free for the first 90 days.
