GaACETech
Oct 18, 2016Guide
AC1750 Primary with 2nd AC1750 as AP
I purchased a AC1750 as a primary router with main SSID and Guest enabled. Both have a password. This works fine.
I purchased a second AC1750 to be used as an Access Point (AP) for a side building (a small cafe). I have the main SSID (called Cafe) and a Guest enabled also (as Cafe-Guest).
Here's the problem: The AP for the Cafe SSID works. However, the guest account (Cafe-Guest) does not get internet access and I cannot ping the default gateway 192.168.1.1.
What gives?
Thanks.
Darryl
Always read the documentation (actually sent to me by DaneA earlier). A main router ethernet port must be used to plug into the 2nd router used as an AP Internet port. I just plugged the 2nd router into a free port on the switch. Funny how the main SSID for the AP worked but not the Guest SSID.
I'll mark this as an answer unless otherwise corrected.
Darryl
1 Reply
Darryl
