jspradley's avatar
jspradley
AC1750 R6400 NetGear Genie and status light say there is no internet but it's actually working fine
So like the title says, NetGear Genie and the amber status light say there is no internet but it's actually working fine. I'm not having any issues with internet or router the performance. Firmware Version is V1.0.1.18_1.0.15
I've tried reseting the router and redoing everything but got the same results.
Any ideas abotu what I can try?
  • Hi jspradley,
    1. Is the router getting a WAN IP on the router UI?
    2. You can try resetting the router?
    3. You can try re-flashing the firmware then reset and reconfigure the router if the issue persists.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi jspradley,
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi jspradley,
    I would like to follow up and check if you are still experiencing the issue.
    Dexter
    Community Team
