shnw's avatar
shnw
AC1750 R6400 Updated firmware to latest version, now internet not working
I have AC1750 R6400, it has been working great without a problem. Yesterday, I updated the firmware to latest version. Afterwards, the internet is not working. What is confusing, when I go to routerlogin.net it says internet status is good, and everything works fine, and there is an IP address, but when you open a web browser nothing is loading at all. I tried so many things to trouble shoot this but nothing worked including: restarting the modem few times. Restarting the router reverting to older firmware versions, several of them down to the initial release, and all without help. I also tried a hard reset and setup the whole thing from scratch twice. I returned it back to the latest firmware since nothing works anyways. Here is where I am at now: AC1750 Router with most recent firmware, internet status on routerlogin.net is good, but I can NOT actually browse the internet. Any ideas, or thoughts to help.
  • Thanks for your help. I gave up and went back to best buy and they exchanged it for me. The new one works well after update so far. Again thank you for your hep
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi shnw,
    I would like to follow up and check if you are still experiencing the issue.
    Dexter
    Community Team
  • I checked the internet directly from the modem and it works great with speeds even above my package.
    So it is not an isp or modem issue I think.
    The internet came back spontaneously through the router for few days but has been slow , way below my package which is 200 mbps but I have been getting 9 through the router.
    Today I am back to the non working status where it says good connection status yet nothing is working.
    I tried mac spoofing using the pc mac and then the modem mac but neither worked, they changed the internet status to not connected.
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi shnw,
      Thank you for the update and confirmation.
      Dexter
      Community Team
