Chanwhitt14
Jun 30, 2022Aspirant
AC1750 R64000 running at half speed
I’ve had my nighthawk router for 2 years and it’s been good for me for the most part so far. I recently had technicians from spectrum come out and test my hardware because our speeds were not up to pa...
michaelkenward
Jul 01, 2022Guru - Experienced User
Usual boilerplate questions:
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
Chanwhitt14 wrote:
When I’m hard wired or wireless to the router, I’m only getting 95 download.
Tested how?
Forget wireless. That tells us nothing abut the wired connection. 95 Mbps isn't that odd for some wifi clients.
- Chanwhitt14Jul 01, 2022AspirantI tested wired and wireless on 2.4 and 5ghz and got about the same result for both. When I ran wires directly to the modem I got 380. When I ran wired to the router it was 98.
Firmware is V1.0.4.122_10.0.95. My modem is an et2251 from spectrum. It’s a modem and only has the one internet port to link to the router.
