AbbeyL's avatar
AbbeyL
AC1750 won't power on
Bought an AC1750 router at the end of October. It worked fine until I returned from the holidays to find it dead - no power, no lights, anything. I replaced the adapter, and it worked until this past week when it died again. It might be related to power outages in my building, but I have it connected to a surge protector. I have tried multiple outlets, the on/off button, the reset button. And of course the 90-day phone support has expired. Any suggestions on how to revive this, or is it time to move on?
  • Try a different power adapter and see if it turns on. Could be there is alot of power surges where you have your router. Sometimes even power strips can't protect electronics 100% of the time. Could have been fried if there's alot of power surges and power outages.
  • > [...] I replaced the adapter, and it worked until this past week when
    > it died again.
       What makes you think that the second adapter is not the new problem?
       What are the ratings of these adapters?  Do you own a voltmeter?  (Or
    know someone who does?)
       One bad adapter sounds like bad luck.  If the second one was a proper
    replacement, then it shouldn't die for years.  Knowing nothing about
    what's in either of your adapters, or what failed in them, it's hard to
    say much with confidence, but I would not expect any fault in the router
    to damage its power adapter, but then work properly with a replacement
    adapter (even for a relatively short time).  Of course, many things are
    possible.
       I suppose that you weren't carefully monitoring the temperature of
    these adapters while they were in use.
    > Bought an AC1750 [...]
       Not that it matters much in this case, but, for future reference,
    note that "AC1750" is a speed, not a model number.  Ever helpful,
    Netgear product packaging emphasizes speeds like "ACxxxx", but that's
    not the model identifier.  Look at the product label.  "R6400" would be
    a model number.
    • wcalifas831's avatar
      wcalifas831
      Prodigy
  • The second adapter has been tested and works fine. It's the router itself that is the problem - likely fried after a couple of power outages in my building, according to the electronics experts I consulted. Apparently it's a common problem. I'm replacing the router, and investing in a higher-quality surger protector and a protection plan.
