Qwan1
Jun 30, 2022Follower
admin password recovery
R6220 All I am unable to obtain my admin login information. I am having a hard time with my teenager and I need to change the wifi password.
If you're unable to use the password recovery (or didn't set it up), then you'd need to factory reset to get back in.
Have you tried the default settings. See the label on the thing.
If that doesn't work, then plemans is spot on.How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
