bryan441's avatar
Feb 28, 2020
Admin password
Hello Guys !
I forgot my router password. Is there any other way to recover the password without resetting my router?
Thanks.
  • > [...] Is there any other way to recover the password without resetting
    > my router?
       A settings reset is the usual remedy for a lost password.  Visit
    http://netgear.com/support , put in your model number, and look for
    Documentation.  Get the User Manual.  Look for "reset".
    • bryan441's avatar
      bryan441
      Star
      Thanks, both of you antinode michaelkenward.
      On User Manual there is NO other option to recover the password without resetting router:mansad:.
      I already reset my router:smileyhappy:.
      • michaelkenward's avatar
        michaelkenward
        Thanks for confirming what I said.
        Don't expect too much of the WNR612v2.
        According to Netgear's manual for this device the LAN and WAN support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware. This may not matter to you, but be warned that it will hobble you if you ever sign up for faster Internet. It also slows down whatever is going on in your local network. Newer devices support 1000BASE-TX.
        Oh, and no 5 GHz wifi. This device does date back to 2009 after all.
