richard42ack
Aug 01, 2021Guide
Admin won't stay logged in for more than a dozen seconds
It has become impossible to manage the router. The routing is working fine otherwise. All clients are being serviced. Indeed, I am using it now to post this. Bandwidth and latency are very good. No i...
richard42ack
Aug 03, 2021Guide
It took me a tedious dozen or so attempts, but I finally got it running for long enough to peek at the logs.
The sequence of note is that it says "login" from xxx
then a few seconds later "login failed" from xxx
where xxx is my machine
This corresponds to me logging in, trying to do something, then getting logged out in the middle of doing it. Nothing, to my knowledge has attempted to login or out except for my initial login.
Richard.
antinode
Aug 03, 2021Guru
> [...] Nothing, to my knowledge has attempted to login or out except
I still know nothing, but I can imagine some problems being caused by
the two sets of credentials used to access the management web site on
these devices (NETGEAR account e-mail address v. "admin"). Combine that
with the multiple names/addresses which can be used in the URL to
specify it, and many things are possible. If a web browser saves one
set of credentials, say, during the initial set-up (with Internet
access), and then, at a later time (without Internet access), the WACxxx
expects the other set, then the browser could auto-fill the wrong
credentials for later authentications.
No bets, but I'd ensure that the browser has no (or, at least, no
unexpected) saved "Logins and Passwords" (Firefox terminology) for any
of the names and/or IP addresses which might be use to access this
thing.
Of course, it's also possible that there's a bug in the fine Netgear
router firmware.
Does the behavior change if it has an Internet connection?
- richard42ackAug 03, 2021Guide
I make it point of not saving admin passwords, so nothing saved there. But will investigate the possibility of an errant browser a little more to see if anything comes of that.
No difference to behavior under any conditions I have tried.
With/without internet, local/remote login.There was a brief period when it stayed logged in for 10 minutes or so, but no particular cause that I could think of. Shortly after that, the logouts were back with a vengeance, giving me barely a few seconds before logging me out.
Thanks,
Richard.
I think I can rule the browser issue out of the equation.
One of the failure modes is that the admin will remain logged in for an extended time, as long as I have clicked 2 or fewer items.
But as soon as the next menu item is clicked, it comes up with "checking internet connection" and then logs the admin out.
This indicates that the action is being initiated by the router.
Richard.
- richard42ackAug 04, 2021Guide
Although not terribly useful, I started wireshark to see if anything unusual was going on. It doesn't seem so. What I see is that out of the blue, not related to anything in particular, the router goes and fetches sso.html
It seems, overall, that the timeout interval has shrunk to an unusably short value. It was always extremely short compared to other routers.
I further presume that the execution of this is lazy. It waits for something else, such as a key click, before it triggers the login timeout check. This explanation of a very short timeout (about 10 seconds), would be consistent with the findings to date.
Richard.
- antinodeAug 04, 2021Guru
> [...] But as soon as the next menu item is clicked, [...]
_Any_ third "menu item"?
> [...] the router goes and fetches sso.html
I'll bite. "goes" _where_? Revealing what you actually observed
might be more helpful than your interpretation of what it all means.Is Netgear support (or a warranty claim) out of the question?
- richard42ackAug 05, 2021Guide
Out of warranty, so no luck there.
You have a good question there about the sso.html.
I didn't note that directly as I should have.I was more interested by when it occurred.
I recall all those requests go to something like accounts.netgear.com
Yes, it seems to be any 3rd menu item or thereabouts. Doesn't seem to matter which one, and I think the governing factor may be how long it takes me to get to the 3rd click.
As to the other poster regarding the dislike of going to the net to login... Totally agree. It is a royal pain that slows the process down. Also the logout times were never very long, which was another frustration -- trying to set up troublesome devices like TVs that don't quite work right was irksome. Playing login whackamole with the devices.
Richard.
- michaelkenwardAug 05, 2021Guru - Experienced User
That is an entry point into into mynetgear.com, and maybe other things.
Mynetgear is also the way into use "anywhere access", Netgear's cloud based "remote management" interface.
Do you have an account on mynetgear.com with your WAC124 device registered?
Does that mean that you see the same behaviour when trying to use a TV's own setup process? So it isn't just the browser GUI for the router?
Did you find this in your research:
Solved: Re: Unable to login after reset - AC2000/WAC124 - NETGEAR Communities
I have no idea if it is relevant.
- richard42ackAug 09, 2021Guide
Not sure what the solution in the link was, because what I see is the original problem followed by a post saying 'glad it is working' Can you identify the thread's post number that gives the solution? All I was able to see was discussion of the problem. None of the links to the solution went to a solution. The one indicator was that the problem was fixed in a given release, but mine was updated beyond that.
I used TV as an example. The point is that setting anything up becomes a difficult process when things are logging itself out every time you turn around. The same is true if you are trying to monitor something and/or isolate a problem. Frequent logouts make life very difficult (and have no useful role in security -- just have to head that one off here -- it is the equivalent of wearing 10 seat belts. Just because 1 is good, 10 is not better. Similarly for very fast timeouts. I also detect a sense of arrogance in some of the Netgear responses on this particular issue, suggesting a very narrow interpretation of clients needs and requirements)
As per the original problem, it seems we do not have a solution. At this point, my main option is to trash the router. This would mean that my very long association with netgear is coming to an end. Netgear were my go-to provider for routers. I would like to bring that router back to life if possible, but that optimism is fading.
The Netgear router is still routing fine, but it is impossible to login long enough to get anything done. Today, it logged me out before even getting past the first menu. So the problem is getting worse, not better. Since starting this thread, I have brought up a new router and am transferring clients to it. That is actually going pretty well.
Is there anything else anyone can think of before ditching Netgear altogether?Richard.
- richard42ackAug 10, 2021Guide
To this question "Do you have an account on mynetgear.com with your WAC124 device registered?" Yes.
My tentative guess is clock skew, but it would be a really poor design if that were the issue. That is, the design did not anticipate that the router clock might drift and end up shutting out admin as a consequence. When I tried to check the time on the router, I got nothing because time is not displayed on any of the pages I can get to within the time limit. And, this is just speculation because I really don't know what is going on in there.
The next item on the router foodchain is another Netgear router (Nighthawk). That, so far, is behaving fine.
I managed to get to the logs, and the last entry was ahead of the current time.
Beginning to look like a possibility here.
Clocks are fine. I briefly managed to get into the NTP page and they accurate to the second.
How, then, does one mess up a token to the point that it requires a re-login within a few seconds?
If the clock is right, and the token has a reasonable validity, what is the mechanism by which this thing keeps logging out?
I looked into the code a little and started experimenting with current_date. It seems that I can set this in the url to get a little more time out of it. I cannot figure out the relationship yet, but a few minutes into the future will allow me to ping about 6 menu items before it logs out. Values well into the future seem to be counter productive.Could be coincidences, anything is possible, but so far got 2 successful runs out of it using approx 4 minutes into the future. That better than I have managed for the past week.
So this little trick of buying myself a little more time on the logins allowed me to find out some more about what was going on.
The status indicators contained errors. For example, it showed one wired device and another wireless device as attached when they were not. Refreshing did not change things.
It is clearly confused about something or other. This is fine, if it wasn't for this awful login business which seems to be fundamentally flawed. Not being able to stay logged in makes it near impossible to administer and find the problem. At this point, it seems more of a Netgear having hiccuped than a configuration issue. (2 reasons: 1 because nothing had changed recently, and 2, everything else is working fine). Either way, wherever the problem is, being able to get into administration to figure it out ought to be the most basic thing that absolutely has to work -- always.
- antinodeAug 10, 2021Guru
> re-login within a few seconds?If fiddling with the time changes the behavior, then I'd wonder about
timezone/DST confusion. I seem to recall seeing complaints here about
both NTP and timezone/DST problems on various models/firmware versions.> [...] being able to get into administration to figure it out ought to
> be the most basic thing that absolutely has to work -- always."always" is another of those tricky "time" concepts. If all you
need to use this thing is a simple time machine, then what kind of
whiner are you?Have you tried any different/older firmware versions?
OK. Here's what I did. I don't know why this worked, or if it would work for anyone else, but I will add it here for the record. And for anyone desperate enough to want to try anything.
I modifed the login url to look like this...
https://accounts.netgear.com/login?....¤t_date=2021:08:09:22:10:51
Where the only thing I changed was to add the ¤t_date= item.
This was set to 3 minutes into the future each time I logged in.
This gave me about an extra 30 seconds of login time. This extra time was just enough to bounce around and see problems, to shut things down and clear apparent errors. Without this hack, I had no chance of seeing anything, it just logged out far too fast. Both the fast logouts and this extended one were employed over many many cycles, so it was not a fluke.
After the cleanups, it is now allowing the usual admin operations.
Whatever the problem was, it had persisted for about a week.Note there is an apparently malformed todo= item. That is not a typo. Someone else can look into that one.
- michaelkenwardAug 10, 2021Guru - Experienced User
Seriously impressive work there on your part. Good of you to report back.
If you want to pursue anything else with your WAC124, or get a message through to the Netgear minders who watch that device, you might like to drop by in the appropriate section for this hardware:
Business Wireless - NETGEAR Communities
There are things in there that might have reduced your frustration:
Search - NETGEAR Communities – WAC124
Apologies for not spotting this earlier. But it is all too easy to get lost in the mess of a "community".
That whiner comment was totally uncalled for.
@ https://community.netgear.com/t5/user/viewprofilepage/user-id/80637
That's OK (when we finally get the right result). I realize these things can be troublesome, although it is easy to forget that when things are not going right. What is more interesting perhaps is what happens after a problem is figured out.
There are a some interesting findings in there, and it would be possible to do better. For example: re-authorization should be guardbanded with sanity checks to ensure it doesn't prematurely keep logging someone out. The current situation suggests that a naive perfect-world assumption drove the design. How exactly it failed may also be interesting to consider. Normally tokens are checked for expiration before advancing further. Yet the clocks were correct, and the NTP used was that from Netgear. Difficult to understand how that went wrong. I wonder if the normally short timeouts were actually intended, or represent some aspect of the same bug/issue related to this.
More difficult would be to figure out why some incorrect entries were kept active for an extremely long time (about a week) when they should have been history. Now I did reboot this thing early on, but didn't keep trying that after it turned out not to work. The main reason not to keep rebooting it was that I had people actively using it for work. So, without some indication it would fix the problem, it was an expensive option. Apart from the admin issue, it was working fine. Accordinging, I bought a new router and started transitioning clients there, but managed to come up with this solution before reaching the point of decommmisioning.One comment in this thread sadly suggests that at least some do not take customer input seriously and/or simply do not care to address the issues.
Thanks,
Richard.
I don't know which comment that was, but most of the reponses here are from other users rather than anyone at Netgear.
There is a small team of official minders who do their best with limited resources. Like most people, though, they probably show more sympathy to people who come across as reasonable individuals. Hang around here for any time and it won't be long before you come across unacceptable behaviour and downright rudeness.
A lot depends on the problem and the device involved. That is why I should have been quicker off the mark.
Some products seem to get more attention that others. Perhaps it reflects the price tag. (For example, gaming routers have their own specialists who are quick to respond, as they should given the cost of those things.)
Pro devices like the WAC124 certainly have their own specialists and, when you hit the right section, less noise traffic to drown out the real signal.
Those gadgets are very different from the consumer stuff that usually comes up in this section which, let's face it, sits at the bottom of the food chain in technology, cost and consumer understanding. As you may have worked out, I've never been let loose on business devices.
https://www.google.com/search?q=sarcasm+wasted
> 1 Kudo
_That_ was predictable.
- richard42ackAug 14, 2021Guide
Fair enough.
It is hard to tell sarcasm from intention based upon text messages though, unless you happen to know the person well.You could presume that my response was also sarcastic...
But no, not true, I got it wrong there. Oops. My mistake there.
Anyway, after a week or so of greatly improved behavior, I would take a fairly reasonable guess that the underlying admin timeout issue has a fundamental flaw or bug in it. This would be behind many of the other threads related to this issue. The fixes in those cases were more likely to be happen-stances that avoided running into the real bug.
Today for example, someone reported that the printer was inaccessible. I got into the router and found that I was getting about 5-6 clicks before logging me out. So it seemed to have regressed a bit. It was better than before when 2-3 clicks was the norm, so that was a little more workable. A few days earlier, it seemed there wasn't a limit.
What I also found was that the printer was listed as on-line, but without an IP address. Checked if we had run out of them (dhcp), no. Power cycled the printer, and it came back on line. Oddly, it was still listed as online even when it powered down, and everything refreshed in the router. Who originally created the problem isn't my issue (who knows). It seems that one apparently-unrelated problem triggers and/or exposes another.
The problem is that the admin should stay logged in long enough to find out where the problem might be.Richard.
- richard42ackSep 23, 2021Guide
And today, the problem is back again. Absolutely nothing has changed since it was last working.
Need to add another machine to the network, but the thing is logging me out before I can get there. What the heck is wrong with this thing? What basic bit of logic is in there that doesn't allow a session to exist for more than a handful of seconds?
It was a dumb idea to route all the logins this way in the first place -- a technology that Netgear have not either thought through or executed properly. Avoid ! as it doesn't seem they will either correctly identify or fix the issue
- michaelkenwardSep 24, 2021Guru - Experienced User
This may sound like an odd one, but I recently had a problem on an R7800 that I fixed by disabling:
Always Use HTTPS to Access Router
Buried in Web Services Management, it seemed to get in the way of using a browser alongside an app to access the router.
That setting was probably a response to requests for more secure access to the graphical user interface. As implemented it seems to upset things.
It may or may not have anything to do with what you see, but it might be worth trying.
- richard42ackSep 24, 2021Guide
Thanks for the suggestion. It seems that it may make sense in that this appears to be a token issuing problem. Such things are time sensitive, and my thought is that there is some clock skew/drift going on. The apparent flaw in the design is that once a token is obtained, it should be valid for a reasonable period without being re-checked. Whatever they are doing seems to be resulting in incorrect attempts to obtain new and unncessary tokens.
My thought is that the clocks have drifted somewhere (even though they are supposed to be all sync'd) and that is a factor.
I haven't found anything suggesting mine was having some https issue, at this point. But I appreciate the suggestion.One brute force approach would be to disconnect it from the internet and thus deny it the means to try to do sso over the internet. However, all users would then also be kicked out, unless I can figure out a more selective means of doing it. In the meantime, I have added another router to the network and added the device there instead.
Thanks,Richard.
- michaelkenwardSep 25, 2021Guru - Experienced User
Another thought, there is a discussion under way on the "Idea Exchange" section. It does not quite fit in with your problem, with a very short interval, but it is along the same lines.
Admin Timeout - NETGEAR Communities
- richard42ackSep 25, 2021Guide
wrt very short timeout link posted: Yep, it was always bad in that regard too.
Did they really mean it to be so short, or did it get messed up in some fundamental way that caused both of the problems? My guess is the latter. The timeout was always so ridiculously short that it is difficult to believe that anyone would have deliberately made it that way.
Richard.
- richard42ackOct 11, 2021Guide
Latest update in here is that the solution to the problem is...
Turn mu-mimo off.
Richard.
