elispeed
Jan 14, 2021Initiate
after firmware update ex3700 , the device wont start
after firmware update ex3700 to the last version , the device wont start.
ok its on but the power led is flashing .
and having NO wifi from it
sounds like you might have corrupted the firmware during the update.
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Also, you might post in the extenders section next time and not the router section. Gets a bit confusing with all the different forums
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
