Sethos099's avatar
Sethos099
After scanning my PC- WARNING Vulnerability ID: NON-2015-0211, help please
  The report said my firmware was out of date and needed upgraded. So, like any reasonable computer geek I checked your site and found the upgrade you suggested to others with the same problem.... upload to v1.1.2.12. I downloaded it and followed the instructions, it failed to upload, multiple times. I looked up my router on your site and went to it's specific download page and on there the latest update was he version I have installed on it (v1.0.0.48), so I'm not sure if there is an update you can direct me to. Any help ywould be greatly appreciated.
Sincerely,
Sethos099
  • ElaineM's avatar
    ElaineM
    Jan 28, 2016
    Unfortunately, there will be no future firmware updates for the router.
    It's because the router is already EOL.
    Consider getting a newer model.
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Hi Sethos099 The firmware will depend on what model number you're using.
    Can you let me know the exact model number and version of your NETGEAR device?
    • Sethos099's avatar
      Sethos099
      Thank you for your quick response, N600 Wireless Dual Band Gigabit Router- Premium Edition, Model WNDR 3800, v 1.0.0.48. I hope this helps, any further questions please feel free to email me back.
      Thank you again,
      Sethos099
      • ElaineM's avatar
        ElaineM
