WantNotTexhNot
Mar 13, 2025Aspirant
All internet settings on router vanished after I changed the SSID password.
As stated above, additionally, my main PC, now plugged into LAN on router, reads as 'Device is blocked by Access Control in the router'.
Other PC will connect wirelessly, and the internet settings fields are empty there as well. No efforts to reset with prior i formation have been successful.
Please help.
Please help.
Please help.
Please help.
- WantNotTexhNotAspirantAs stated above, additionally, my main PC, now plugged into LAN on router, reads as 'Device is blocked by Access Control in the router'.
Other PC will connect wirelessly, and the internet settings fields are empty there as well. No efforts to reset with prior inormation have been successful.
Please help.
Please help. - michaelkenwardGuru - Experienced User
WantNotTexhNot wrote:
As stated above, additionally, my main PC, now plugged into LAN on router, reads as 'Device is blocked by Access Control in the router'.Hard to follow what is going on there.
Where do you see this message?
As to the subject "All internet settings on router vanished", where are you looking?
Other PC will connect wirelessly, and the internet settings fields are empty there as well.Empty in what? Are you using a web browser and the graphical user interface (GUI)?
No efforts to reset with prior i formation have been successful.What do you mean by "reset". You have factory reset the R6220?
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
Finally, what modem/gateway/ONT (make and model) connects the router to the internet?
Disclaimer: Just another user with time on their hands.
- WantNotTexhNotAspirant"Where do you see this message?"
The message 'Device Blocked in Access Control,' appears when I enter router management settings at 192.168.1.1, using browser.
"As to the subject 'All internet settings on router vanished', where are you looking?"
In the router management section titled "Internet Setup"
No, I have not reset the router using factory settings.
This view of the empty occurs when I attempt to re-enter the prior known configurations in Advanced> Internet Setup.
There it asks for Internet IP address, DNS Address, and Router MAC Address.
The Modem is from Charter Spectrum: D3.1 2.5G eMTA
Model: ES2251
You have asked for the Gateway info.
Not seeing how it would be safe to place that in an open forum.
Thank you for parsing out my inquiry.- CrimpOnGuru - Experienced User
If the router will not allow access, there is no opportunity to make any changes. Although a Factory Reset is often thought of as a Last Resort (because it erases any configurations the user may have done - in my case about two hours of typo-ridden entries), this seems to the situation here.
I would Factory Reset this unit and start from scratch.
