mdherms's avatar
mdherms
AP Mode R6220
I have an R6220 setup in AP mode connected to an R7000. Works fine. My question is does the CAT5 cable need to be connected all the time to the R6220 to reach back to the R7000 or can it be disconnected and connect back wirelessly? It doesn't really say in the manual if it needs to remain connected. I'd like to disconnect it and move the AP to a different part of the house but I can't run a CAT5 cable to that area. If it has to remain connected this product will not work as an AP for me. What would be a better choice as an AP?
  • I will look for a "Wireless Network Extender"
    Thank you!
  • > [...] It doesn't really say in the manual if it needs to remain
    > connected. [...]
       Does it say that you can _disconnect_ it?  (Answer: No.)
       Something other than a wireless access point.  Pretty much by
    definition, a WAP is wire-connected to the main router.
       There exist wireless network extenders which can use a wireless
    connection to the main router.  There are also Powerline devices which
    can use existing power wiring to emulate a real Ethernet cable.  Many
    things are possible, but if you don't want to run a cable (or
    equivalent), then you don't want a WAP.
       You might try a Web search for terms like, say:
    • mdherms's avatar
      mdherms
      Thank you!
