cssaus
Nov 28, 2018Aspirant
Attaching a Switch to a WNDR4500 Router
My WNDR4500 has all 4 LAN connections occupied. I would like to know if I can attach a Switch to one of the LAN ports in order to expand the number of connections.
Thank you.
Steve
- Nov 28, 2018
> [...] I would like to know if I can attach a Switch to one of the LAN
> ports [...]
Yes (assuming that you have a switch and a cable).
TaterSalid
Nov 29, 2018Virtuoso
A simple "yes' would have been preferred.
That being a Gbit router, a Gbit switch would serve you better in the future.
- antinodeNov 30, 2018Guru
"preferred" by whom, you? Who cares?
> future.
"would"? Your confidence is impressive. I'd say that it _might_,
but that could depend on the devices to be connected to the switch.
With my weak psychic powers, I can't determine that from the available
information. I have a few old printers and other "Fast" Ethernet
devices which wouldn't care if they were connected to a gigabit switch
or something slower.
