civ_engineer's avatar
civ_engineer
Follower
Jul 14, 2018
Best method of extending wifi signal with netgear gateway c6900
I have a netgear gateway c6900 I bought at costco. I need something to boost the signal to the rest of my house. What would be the best option?
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi civ_engineer,
    Welcome to the community!
    You may look into some range extender on this link.
    Dexter
    Community Team
    • Eric_Cartman's avatar
      Eric_Cartman
      Guide
      i have two Model: EX7000 range extenders one in access mode other extender mode paired with an x6 r8000
      the ex7000 in AP mode is brilliant when working i was to far from original router to get 5ghz but with the AP I get 5ghz perfect. few teething problems setting up but when it works its FAB
