kakarott
Nov 22, 2018Tutor
Best router for > 40 connected devices
Hello,
a) I'm looking for a router which can connect 40 devices or more (wirelessly, simultaneously). Any suggestion on the cheapest router for that?
b) I'm eyeing the D7000 Nighthawk or the ...
- Nov 27, 2018
Thanks for the advice! Turns out each manual uses different word for device/client/node (I did a CTRL + F). From the manual:
Nighthawk D7000 : The modem router can support a maximum of 256 clients:
- Maximum number of wired clients: 128
- Maximum number of 2.4 GHz WiFi clients: 64
- Maximum number of 5 GHz WiFi clients: 64
- In a WiFi network, the maximum number of clients is limited by the amount of WiFi traffic that is generated by each client.
Nighthawk R7000 : Maximum computers per wireless network : Limited by the amount of wireless network traffic generated by each node (typically 50–70 nodes).
TaterSalid
Nov 27, 2018Virtuoso
The most I have tried to run is 30. If Netgear is limited to 32/64 then a commercial grade router may be what you need. Consider EdgeRouter.
kakarott
Nov 27, 2018Tutor
Is your Netgear router = single band or dual band?
- TaterSalidNov 27, 2018VirtuosoIt is a dual band R6020. I set it for 30 hosts. One of those is the router so it was 29 hosts addresses that I reserved. I haven’t had all devices connected but the router didn’t complain about the config.
- TaterSalidNov 27, 2018VirtuosoHave you downloaded the manual for your chosen router?
This router, R6020, is $30 to $35us. I have 3. One has been a problem. Unless you will do heavy streaming it will be fine. It will handle two TVs if you have the Internet speed to support them. Good luck.
The manual: https://www.netgear.com/support/product/R6020.aspx#docs
From the manual:
DHCP range 192.168.1.2 to 192.168.1.254
Maximum computers per WiFi network - Limited by the amount of WiFi network traffic generated by each node (typically 50–70 nodes)
- kakarottNov 27, 2018Tutor
