kakarott
Nov 22, 2018Tutor
Best router for > 40 connected devices
Hello,
a) I'm looking for a router which can connect 40 devices or more (wirelessly, simultaneously). Any suggestion on the cheapest router for that?
b) I'm eyeing the D7000 Nighthawk or the ...
- Nov 27, 2018
Thanks for the advice! Turns out each manual uses different word for device/client/node (I did a CTRL + F). From the manual:
Nighthawk D7000 : The modem router can support a maximum of 256 clients:
- Maximum number of wired clients: 128
- Maximum number of 2.4 GHz WiFi clients: 64
- Maximum number of 5 GHz WiFi clients: 64
- In a WiFi network, the maximum number of clients is limited by the amount of WiFi traffic that is generated by each client.
Nighthawk R7000 : Maximum computers per wireless network : Limited by the amount of wireless network traffic generated by each node (typically 50–70 nodes).
TaterSalid
Nov 27, 2018Virtuoso
This router, R6020, is $30 to $35us. I have 3. One has been a problem. Unless you will do heavy streaming it will be fine. It will handle two TVs if you have the Internet speed to support them. Good luck.
The manual: https://www.netgear.com/support/product/R6020.aspx#docs
From the manual:
DHCP range 192.168.1.2 to 192.168.1.254
Maximum computers per WiFi network - Limited by the amount of WiFi network traffic generated by each node (typically 50–70 nodes)
kakarott
Nov 27, 2018Tutor
