lacuentadelui
Apr 14, 2021Aspirant
Best WIFI 6 replacement for the R6300v1?
Hi everyone! Since 2015 I have those netgear products: NETGEAR Smart WiFi Router AC1750 Dual Band Gigabit Netgear AC750 -802.11AC Dual Band Gigabit Wi-Fi Range Extender (EX6100) I think it's t...
lacuentadelui
Apr 20, 2021Aspirant
1. what size is your home?
2000 suare feats.
2. what is the home made up of for interior walls?
Bricks
3. what speeds do you pay for or plan on upgrading to?
120Mbps.
4. What is it used for? gaming? streaming? 50+wireless devices, etc
20 devices. Working & streaming.
5. whats the budget? Again, there's a best for every price point
No more than 200 USD.
Apr 20, 2021Guru - Experienced User
Brick walls make it a challenge as brick blocks wifi well.
For a single router solution, I'd recommend the R7800 or XR500
For mesh solutions, you can find the renewed RBK43 system at times for around that price.
- plemansApr 20, 2021Guru - Experienced User
If you're looking at wifi 6 and under $200 (harder to do) then you're looking at the rax40 or a MK60 system (with only 1 satellite)
