Smoker21
Jul 21, 2022Aspirant
Best wifi router around/under $150?
I already have a Motorola modem, an Xfinity 100 mbps package, and a residence that is about 2750 square feet. Are there any reliable routers in the $150 to $200 pricing range?
Jul 22, 2022Guru - Experienced User
You can find good prices or deals on 2nd hand or refurb units if you don't mind trying one out.
https://www.amazon.com/Netgear-Nighthawk-6-Stream-AX4300-Router/dp/B086ZNJ1J2/ref=sr_1_2
I've bought two NG refer'b routers from Amazon. Both were basically unused or new. R8000 and R8500. I was lucky I guess.
