PXRG
Aug 11, 2015Tutor
Blinking power light - but not all te time
I have the (apprently quite common) problem of a blinking power light on my R6300 router. Manual and forums say this could be a firmware problem or a problem with the power supply to the router. My...
- Aug 11, 2015
I've had the same issue on a 6300. I was lucky and managed to reload the firmware, and was was back to normal in no time. I would reload the firmware while you can..
Daenerys
Aug 11, 2015Luminary
It seems firmware issue to me but I also recommend to try different power supply for further isolation. What version are you using by the way? If it is version 1, make sure to update it to the latest firmware version.
PXRG
Aug 15, 2015Tutor
I am not sure whether I have V1 or V2. The model number on the router does not include a version and I cannot get into the configuration utility to see whether that says! I huess I have a V1.
