PXRG
Aug 11, 2015Tutor
Blinking power light - but not all te time
I have the (apprently quite common) problem of a blinking power light on my R6300 router. Manual and forums say this could be a firmware problem or a problem with the power supply to the router. My...
- Aug 11, 2015
I've had the same issue on a 6300. I was lucky and managed to reload the firmware, and was was back to normal in no time. I would reload the firmware while you can..
VE6CGX
Aug 15, 2015Master
TTL=100 means router is waiting for firmware load. Either your AC power adapter is flaky or router is
flaky. When it is normal TTL=64. When light is not blinking try to repoad f/w and factory resey, reconfigure
to see it settles down. If you want to load f/w when light is blinking use tftp method.
PXRG
Aug 15, 2015Tutor
Thanks - I used the tftp method and it now seems fine. Fingers crossed it was corrupted firmware. Not sure how it got corrupted though ...
