Agustingc's avatar
Agustingc
Initiate
Jul 12, 2016
Block intruders
I have a R6300v2 Router and I cant found the option to Block or Deny a specified MAC address.
I have a coffee shop an I offer a free internet service to my guest, but I need to deny the Internet access to specific users. I dont know how do that.
When I activate "access list" feature, I can't create a black list, only I can create a white list.
I will appreciate your support.
Regards
  • Hi, thanks for your support. Your suggest solved my needs but I can't believe that this high-end route don't have this feature.
    Beat regards
  • Retired_Member's avatar
    Retired_Member
    I don't believe that router offers access control. Since you have the Mac addresses you CAN use address reservations and then set a rule to block all services for those IP's.
    Beat regards
      Retired_Member
      You're Welcome
