JayMan01's avatar
JayMan01
Block Sites List Truncating
So i just noticed this today when I was trying (and failing) to add addtional IPs/URLs to block.
For some reason it has stopped letting me add anymore.
I also notice that when I try that just the first 3 characters of the IP/URL is added.
So for some reason it is truncating after 94 characters (in 8 lines).
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hello JayMan01,
    I understand that you are having issues adding additional IPs/URLs to block using the NETGEAR interface. Please provide the device's model number so I can further assist you.
    I look forward to hearing from you!
    Best,
    Kevin
    • JayMan01's avatar
      JayMan01
      Hello,
      Thank you for the reply.
      Its is the WNDR3700v4.
      Thanks in advance.
      • michaelkenward's avatar
        michaelkenward
        JayMan01 wrote:
        Hello,
        Thanks in advance.
        That router is from 2015, seven years ago, with its origins in 2009.
        Don't expect much.
    • KevinLiT's avatar
      KevinLiT
      NETGEAR Moderator
      Hello JayMan01,
      We have been working diligently to figure out a solution to your issue.
      Please provide the following:
      Firmware:
      Screenshot with truncation issue:
      Best,
      Kevin
