KristofferB
Oct 24, 2017Aspirant
Blocked from certain domains. WNDR4300 Router
I have encountered a problem that I can't solve with my router. It seems I am blocked on some domains for some reason and the problem seems to be with the router. I get the ERR_CONNECTION_REFUSED on ...
- Oct 25, 2017
I just performed a factory reset (how stupid of me to not try this before!) and it have solved my issue!
ElaineM
Oct 25, 2017NETGEAR Employee Retired
Welcome to the community, KristofferB
When did the issue happen?
Are you using the latest firmware of the router?
Did you try reinstalling the firmware?
If you have not, try that and see if it will help.
KristofferB
Oct 25, 2017Aspirant
Hello, and thanks for the reply. Difficult to say when it happened, but it has been at least 6 months. I installed the latest firmware a couple of days ago but that didn't help. What do you mean by reinstalling firmware and how do I do that?
