raik2619's avatar
raik2619
Follower
Aug 29, 2015
Bridge setup with comcast--need to change password
Hi,   I have a NetGear R6300 that I use in conjuction with my comcast router (comcast router serves a bridge). I am able to access the comcast router, but cant access the netgear router. We use the...
  • TheEther's avatar
    Aug 29, 2015
    The default password should be "password" without the quotes. You can change the password after you log in.
