cuse165
Jun 23, 2018Aspirant
Bypassing my DNS
I added a DNS that blocks adds when I am online I see every add there is so I tried another DNS same thing so the I tried opendns and same thing as the other two. My router is like bypassing my setti...
- Jun 23, 2018
Well first I would like to thank you for your rude answers and how you put your answer was uncalled for. If you had nothing to say dont answer my question. Dont take my question and pick it apart and be a smart ass Next time I need a smart ass answer I know who I can contact.
cuse165
michaelkenward
Jun 24, 2018Guru - Experienced User
Apologies for that. Most of the regulars here try to be helpful without being rude or to belittle people.
Did you fix your problem?
My approach to "ad spam" is to use a browser add-in that blocks ads.
Messing around with DNS servers is a bit too complicated and open to error for my liking. I don't recall anyone else using that approach, so I doubt if you will find much around here on that topic.
- cuse165Jun 24, 2018AspirantWell thank you I do apologize for what I said. I was just looking for info
- michaelkenwardJun 24, 2018Guru - Experienced User
cuse165 wrote:
Well thank you I do apologize for what I said. I was just looking for infoYou have nothing to apologise for.
I hope I provided some info, rather than insults. Apologies, again, if my info it isn't what you want.
Like I said, your request is a bit out of the ordinary. The solution doesn't really depend on the hardware – all routers will have the same issues – so you might like to cast the question into a wider community, where people talk more about ads and how to get rid of them.
If you do find an answer, it would be great if you came back with the answers you find.You never know when someone will turn up on a similar quest.
