bob56's avatar
bob56
Tutor
Jan 17, 2022
C6230
My wife logs in on her IPhone and after a few seconds it kicks her offline. Can someone help?
  • plemans's avatar
    Does it say why its kicking her off?
    What band is she connecting to? 2.4ghz or 5ghz?
    Is any other device having issues or just your wife's phone?
    • bob56's avatar
      bob56
      Tutor
      Problem solved but thank you very much for the response.
      • plemans's avatar
        Might mark it as solved and what you did to fix it to help out others with the issue. Either way glad it's working!
