FL20
Dec 09, 2020Aspirant
C6250 cannot lock upstream
Hello the amazing community
My internet went down about 2 hrs ago, upstream channel LED blinking, called xfinity service they said the can see the modem online. Multiple power cycle/plug unplug attempts did not help.
Looking into the cable connection page it shows only one downstream channel is locked at -0.1dBmV power and 41.4dB SNR while no Upstream channel is locked power was 27.3 dBmV, as shown in the attached image.
Does this mean I have a line issue or is it on the modem? Would you advise my next step?
Thank you
Francis
Thank you
Francis
- FL20AspirantI am having problen uploading images, I type the Cable connection content below:
Upstream Parameters acquired
Downstream
Channel 1
Status Locked
Modulation QAM256
ChannelID 20
Frequency 669000000 Hz
Power 0.4 dBmV
SNR 40.3
Correctables : 0
Upstream
Channel 1
Status Not Locked
US channel type : ATDMA
Chnn ID 3
Symbol rate: 5120 K
Frequency 26000000Hz
Power 53dBmV - plemansGuru - Experienced User
do you have a screen snip of the cable connection page and the logs?
That helps.If you have any splitters, amplifiers, or attenuators in line, remove them.
