Skoot3r
Dec 13, 2020Aspirant
C6300 Upstream light flashing
So I recently moved my modem upstairs which required me to rewire/reroute some coax cables. The first day it worked just fine, I moved it to my room for faster download speeds on my pc which is connec...
Skoot3r
Dec 14, 2020Aspirant
So this is the screen snip for my cable connection screen when it is plugged in downstairs, however I can't even get a screen snip of the page when its upstairs because it claims my modem is offfline, so this screen doesn't show up in the first place.
Dec 14, 2020Guru - Experienced User
pictures can take several day to show. If you add them by click on the "choose file" option, we can ge them right away
- Skoot3rDec 14, 2020Aspirant
my bad, new to all of this. I've never needed to come here until now
- plemansDec 14, 2020Guru - Experienced User
so in the location that it works, your powerlevels are a bit boarderline. The upstream shouldn't be much higher than what it is and the downstream should all be within 3.5dbmv of each other and you're right around that. adding distance to the line probably pushes you over limit.
So is there no way I can go about fixing this? Is there no work around even with the added distance? And in that case does that mean I'll just have to keep the distance short regardless? Because as I said earlier the modem worked fine the first day in the second location, but stopped working the day after.
