Skoot3r
Dec 14, 2020Aspirant
C6300 Upstream light flashing
So I recently moved my modem upstairs which required me to rewire/reroute some coax cables. The first day it worked just fine, I moved it to my room for faster download speeds on my pc which is connec...
Skoot3r
my bad, new to all of this. I've never needed to come here until now
Dec 15, 2020Guru - Experienced User
so in the location that it works, your powerlevels are a bit boarderline. The upstream shouldn't be much higher than what it is and the downstream should all be within 3.5dbmv of each other and you're right around that. adding distance to the line probably pushes you over limit.
- Skoot3rDec 15, 2020Aspirant
So is there no way I can go about fixing this? Is there no work around even with the added distance? And in that case does that mean I'll just have to keep the distance short regardless? Because as I said earlier the modem worked fine the first day in the second location, but stopped working the day after.
- plemansDec 15, 2020Guru - Experienced User
You're boarderline before you add the distance/extension. what you can try doing is check the line before that point. remove any splitters, amplifiers, attenuators, or extended runs. that might allow you to extend the run to a different location. You might also check the current connections for loose connections, damaged/old/cheap connections.
- Skoot3rDec 16, 2020Aspirant
Alright cool I'll try that. And if that doesn't work then what? It just has to stay there? Also so this isn't a question of my router at all then? As in my modem isn't the problem so getting a new one wouldn't help at all?
