DW123456's avatar
Aug 31, 2020
C6300v2 not emitting WiFi signal
Hi all,
For no apparent reason my router/modem has stopped emitting it's WiFI signal. I've tried power cycling, rebooting and following the instructions if the inner 'radios' are on or off. Nothing works. Wired device connections work fine.
Cheers,
Dave
  • Glad to hear it! if you mark it solved it can help the next person
  • plemans's avatar
    Did you try pushing the wifi on/off button for 2 seconds?
    • DW123456's avatar
      DW123456
      Tutor
      I have tried that several times. Same with powercycling.
      • plemans's avatar
        Factory reset? Push and hold the reset button for up to 30 seconds while powered on?
