vikasG's avatar
vikasG
C7000-100NAS ethernet works but no wifi
This was working fine for 2 years. Suddenly the Wifi on both 2.4 and 5 GB STOPPED showing up on my devices. However, the ethernet is working fine. Everything shows Good on the router.login. Please help
  •     Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.  Look for the
    LED descriptions and "Troubleshoot".  Pay particular attention to the
    "WiFi On/Off button with LED".  Did you press it?  Further reading might
    not hurt, either.
    • vikasG's avatar
      vikasG
      Did all of that and had no luck. Hence I raised it here. When I go in through Netgear gini or the laptop to connect to the router, the wifi shows everything is good and green. Very confusing
