Diemerson's avatar
Diemerson
Follower
Mar 18, 2020
Cable modem CG3000D
I have the cable modem CG3000D, his wifi says it is N technology, but it is not more than 35 mega in WiFi, what procedure to solve? Thank you very much in advance
  • N300 is 2.4ghz based. 2.4ghz is inherently slower than 5ghz and its even made worse in congested environments.
    procedure to get more speed? add in an router/access point that supports 5ghz or upgrade the router to wireless AC/AX.
1 Reply
  • plemans's avatar
