HenryStock
May 07, 2017Aspirant
Can I control IP addresses by MAC address?
A previous router that I owned gave me the capability to assign a specific IP address to a specific MAC address so that I could still use DHCP and control the IP addresses of specific devices at the ...
- May 08, 2017
Use DHCP reservations. It provides the functionality you are looking for.
TheEther
May 07, 2017Guru
HenryStock wrote:
A previous router that I owned gave me the capability to assign a specific IP address to a specific MAC address so that I could still use DHCP and control the IP addresses of specific devices at the same time.
Netgear calls them DHCP Reservations. You can set them up in the Advanced LAN Setup screen on the router.
Right now I am having a conflict between two devices, my computer's Ethernet connection and my wife's IPAD wireless connection. Both have the same IP address so that one is connected to the network, the other has issues.
My computer runs Windows 10 and I have tried the ipconfig /release and ipconfig /renew commands. But, I have been trying to release the specific connection. I haven't figured out what I am doing wrong. The problem seems to be that it has a "preferred address" that it doesn't seem to want to give up, 192.168.1.27, which is the same as my wife's wireless IPAD device.
Do you, perhaps, have your computer set up with a manually configured IP address?
I also have a wireless connection from this computer, but I was hoping to take advantage of both.
While this is possible Windows doesn't really do a good job of it. Why do you want to do this? Ethernet is much faster than Wi-Fi.
