HenryStock
May 07, 2017Aspirant
Can I control IP addresses by MAC address?
A previous router that I owned gave me the capability to assign a specific IP address to a specific MAC address so that I could still use DHCP and control the IP addresses of specific devices at the ...
- May 08, 2017
Use DHCP reservations. It provides the functionality you are looking for.
HenryStock
I sometimes move around. The ethernet connection is only at my desk. If I move up to the family room I have to disconnect from the ethernet and use wifi. I could turn wifi on and off, but I don't really want to do so.
I understand that MAC addresses are unique, so theoretically it should be possible, if the router has the command software, to assign specific IP addresses to specific MAC addresses via DHCP. I used to use that to separate my printers from other devices.
TheEther
May 08, 2017Guru
