Elle01
Jan 28, 2022Tutor
Can I update firmware via webpage file upload from MacBook using WIFI instead of hardwired cable?
Hiya,
Thanks to help here I've finally figured out how to upload a frimware update file that was refusing to do it's thing quoting Unknown Error 1 .. Despite the fact I am now able to do steps 2 - 7 of the 'How do I manually update the firmware on my router' help article ,
( https://kb.netgear.com/23442/How-do-I-update-the-firmware-on-my-NETGEAR-router-with-a-web-browser# )
I'm falling at the first hurdle.
Step 1... Connect your computer to your router with an Ethernet cable.
I don't have an RJ45 port on my macbook and my adaptor is broken (never worked properly to begin with, connection constantly dropped in and out)
QUESTION - Is it possible (safe/reliable/won't brick the router) to do this firmware file upload and update using a WIFI only connection between router and laptop??? The article makes no mention of this.
Many thanks in advance.
Update..
I started this question as a new topic thread - someone kindly answered it as part of a different question I posted. I can't see how to delete the above post so I will post the answer here incase it helps anyone else too...
"You can do it over wifi.We recommend over wired because its a solid connection without interference.
But wifi does work."
Thank you to 'Superuser' 'Plemans' for the answer. :smileyhappy:
1 Reply
- Elle01Tutor
Update..
