swaasje's avatar
swaasje
Can I use wifi router as a switch?
Can i disable the wifi and the DHCP table to use the router as a switch?
  • > All done. [...]
       _What_, exactly?
    > I am worried that the status says DHCP ON
       I'd guess that that's accurate only if the router is acting as a
    router, not when it's configured as a WAP.
    > The Genie offered to use the Netgear as an AP
       After a settings reset, if it sees a private address on its
    WAN/Internet interface, then it might draw the correct conclusion
    automatically.
    > I kept SSID broadcast on recommendation. [...]
       That doesn't matter much if the radio is disabled.  The point was
    that "Enable SSID Broadcast" and "Enable Wireless Router Radio" do
    different things.
    > So DHCP organises the different ports? [...]
       I'd say "connected devices", not "ports".
          https://en.wikipedia.org/wiki/Dynamic_Host_Configuration_Protocol
    > I had problems in the past with WAP acting like a router and
    > distributing weird IP addresses on our network.
       Generally, you want one DHCP server per LAN.  Multiple uncoordinated
    DHCP servers can cause many problems.  Which is why the one-step WAP
    mode option disables the DHCP server.  (And, why you would need to
    disable it explictitly, if you don't use the one-step WAP mode option.)
       So, it works as expected now?  (What could go wrong?)
       Possibly interesting:
          https://kb.netgear.com/26765
  • > Can i disable the wifi and the DHCP table to use the router as a
    > switch?
       Should be possible.  Visit http://netgear.com/support , put in your
    model number, and look for Documentation.  Get the User Manual.  Read.
    Look for "Use the Router as a Wireless Access Point".  If you really
    want to disable the radio, then look for "Control the Wireless Radio".
    • swaasje's avatar
      swaasje
      Thanks. I can't go in with the IP address or the routerlogin.net or .com
      So can't change settings.
      • antinode's avatar
        antinode
        Guru
        > [...] I can't go in with the IP address or the routerlogin.net or .com
           "can't" is not a useful problem description.  It does not say what
        you did.  It does not say what happened when you did it.  As usual,
        showing actual actions (commands) with their actual results (error
        messages, LED indicators, ...) can be more helpful than vague
        descriptions or interpretations.
           Which "the IP address"?  From what?  Connected how?  Even the
        slightest trace of useful information might be helpful.
           In the User Manual, look for the LED descriptions and "Troubleshoot".
        Also, "Factory Settings" or "Reset".
