Mike37's avatar
Mike37
Can not access the www.routerlogin.net or www.routerlogin.com or IP Address for my WNDR3800 Router
Hello I trying to access my Wifi on the wndr3800  Router , i dont know the passwords, i looked on line and none of web sites to access this Router are working www.routerlogin.net or www.routerlogin.com or using my IP address 192.108.01 can you help ! Thank YOU Mike
  • www.routerlogin.net and www.routerlogin.com are used to log into your router's management portal.  You must, of course, be connected to your router's network (through Ethernet or Wi-Fi) in order to log into the router.  If you don't know your router's Wi-Fi password, then presumably you are not connected via Wi-Fi.  Do you have a computer with an Ethernet?
    The WNDR3800 uses a default IP address of 192.168.1.1.  192.108.01 is not a properly formatted IP address.  Netgear has an article that details how to find the IP address of your router.
