dbro
Feb 07, 2017Aspirant
Can you have two wireless networks if you have two modems but only one computer?
I had time-warner install a cable modem and bought an AC1700-6400 wireless router. The tw tech could not get the wifi to work but was in a hurry so told me to call support. I asked him if I could have two wireless connections at the same time, he said yes. I have not shut down my ATT Uverse because it is connected with wireless to my TVs and Rokus. The account is good until 15 Feb. I was going to use the same name and password as my old wireless connection so that I wouldn't have to change everything in the house thats wireless. Is the Time-Warner man correct that I can have two wireless connections in the same house? I am using one computer for the wired network that is connected to TW. It does not make any sense to me. I figured I would have to shut down my ATT Uverse and wireless connection before the Netgear router will make a wireless network. Am I correct?
You cannot run a single seamless wireless network with two different ISPs unless you use a dual-WAN-capable router or load balancer. With your current equipment you can run two separate wireless networks. Switching between will not be seamless.
- William10aMaster
There are load balance devices that allows two or more modems to serve as one lan to your router or computer D-Link makes one has a review showing it work. The person reviewing says that you can control the setting on the device too. There a link on one of the posting share part of the community with a link to the youtube video. Netgear needs to come out with one if they have one now. Sorry can not remember which posting it was in but a web should find it.
- William10aMaster
Here is the link for D-links load balance device for up to four modems to a single lan feed https://www.youtube.com/watch?v=YDUfP8a5zNY.
- dbroAspirant
Thanks for your help. I can't seem to get anyone that I have spent money with to give me the correct answer. Very frustrating.
