Melsmeeusen
May 31, 2016Aspirant
can you still use WEP key?
Hello people, I was wondering if it is still possible to use a WEP key. I want to go online with my nintendo DSI for the fun, but you need to have a WEP key, otherwise it can't get on your WIFI-r...
- Retired_MemberJun 01, 2016
choose 54 as mode then it should be listed
then setup guest using WEP and main using WPA2 or WPA The link rate will be 54 on both
VE6CGX
May 31, 2016Master
Of course if router has a setting for that.. Better than no security at all, LOL!
- MelsmeeusenJun 01, 2016Aspirant
And do you maybe know where I could find this setting? because right now I can only choose between:
- none
- WPA-PSK (TKIP)
- WPA2-PSK [AES]
- WPA-PSL [TKIP] + WPA2-PSK [AES]
Is there maybe a setting I need to turn on first, before I can use WEP?
And would it also be possible to have a WPA and WEP key password at the same time?
I could also take off the password, but yeah, I'd like to have some kind of protection! haha
