sanja_nvkz
Jan 20, 2018Follower
Cancel password reset request
Hello community, I tried to reset the router password but remembered it afterwards. Now I'm still able to login to my router at http://routerlogin.net/ but when I try to login by entering the IP...
- Jan 25, 2018
Hi sanja_nvkz,
1. Please try using another browser or device to login.
2. If the issue persists, you can try doing a factory reset.
Dexter
Community Team
DexterJB
Jan 25, 2018NETGEAR Moderator
Hi sanja_nvkz,
Dexter
Community Team
- DexterJBJan 29, 2018NETGEAR Moderator
Hi sanja_nvkz,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
