mallman2's avatar
mallman2
Cannot access wifi using other access points
WNDR4500v3 with firmware V1.0.0. I32
I purchased this router on dec 25 2015 to replace a dead linksys router.
The router feeds a 16 point switch from one of 4 ports.
I have one win 7 pc connected to one of the routers other 3 ports.
Then an VoIP connected to the 3 port of the router.
I have 2 other wireless access points connected to the 16 port switch.
One feeds a remote building by a wired connection to firset access point
The other access point is also feed by a wired connection.
The old linksys router had done this for 4 years.
As I said I purchased this router as an replacement... but since its worthless and the two wireless access point have not internet connection.
So either I get it working or its going back for a refund in 24 hours.
  • mallman2's avatar
    mallman2
    Jan 13, 2016
    Figured it out it was windows network and sharing manager marking the connection as unknown.
    In advanved sharing setting I had to change to use user accounts and passwords to connect to other computers
    Then all the problems went away.
    No more dropping connection and having no internet connection.
  • Retired_Member's avatar
    Retired_Member
    I suspect an IP conflict because you said Nothing about how it's setup other than what's connected to the lan ports. Or the switch needs to be configured if a smart switch. Since it's worthless return it.
    • mallman2's avatar
      mallman2
        Retired_Member
        Good for You!
        Thanks for the update!
