stpham168
Feb 05, 2021Follower
Cannot establish wifi signal on Netgear extender to Fios router
Following the Netgear instructions to connect the NetGear extender to the new router Verizon Fios WiFi 6 but failed after may attempts (5 times). No LED appeared on the Link status on the NetGear Extender. What should I do to have they connected? The new router has no "WPS" button to sync with NetGear Extender! Can some one gives me guidance. Thank you.
SonPham
1 Reply
Which fios router is it?
Are you using the installation assistant on the EX8000?
where is it failing in the process?
